I have 2 computers and both have micosoft wireless keyboard and mouse combos on them. The problem I am having is that recently I moved the computers from one room to the other and ended up syncing my keyboard to my wife's computer. Now my keyboard is controlling both computers. I can go into device manager and uninstall the extra keyboard on her computer but when she restarts it just reinstalls it. She has windows xp and it does not give you the option to disable a keyboard. What I am looking for is a way to stop her computer from reinstalling it or a way to disable it.
Sync keyboard to one PC while other is switched off, then switch it off and sync other keyboard to the other PC. If it still controls both PC's repeat syncing on one of them while the other is switched off. Every time You do syncing it choose another channel.
I had a similar issue before. A friend and I both had similar wireless Logitech mice. I could move his cursor with my mouse from a few feet away. Kind of strange...
------------------------------Antec P182, i7 920 3.7Ghz @ 1.3V, Xigmatek 1283, Asus P6T X58, 3 x 2048MB OCZ Plat DDR3 1600 RAM, 2 EVGA GTX260 Core 216 in SLI, WD 160gb,320GB 1TB WD Black. Corsair 750TX. Acer 24" Monitor. Vista x64 Home Premium.
Reply to one-shot
Sorry it took me so long to respond. I tried that and it did not help.
