Hello my Overclock Experts:
HELP ME GET A COOLER THAT PERFORMS JUST LIKE THE D14 OR BETTER IN THE 100$ RANGE.
I am building a gaming machine and i need some Suggestions on what CPU Cooler buy.
I Ordered the Corsair Vengeance Blue 16GB Kit and the ASRock P67 Extreme4 so far. I will be buying the Intel i5 2500k for gaming and im going to push it to at least 5ghz stable!
ASROCK P67 EXTREME4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
CORSAIR VENGEANCE BLUE
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145347
I was going to buy the Noctua D14 but by the time i bought the RAM is was too late , these RAM are TALL and cant fit under the D14 unless u trim your Ram and i dont want that.
I Saw the Noctua C14 and the only way to fit this RAM under it is removing the FAN on the bottom of the Radiator, i want Maximun Performance without removing anything. If i do that it'll be something like this:
http://forum.corsair.com/forums/attachment.php?attachmentid=8167&d=1299548868 AND THAT LOOKS UGLY AS FAQ!
ASROCK P67 EXTREME4
