Hey guys I am currently overclocking my x4 955, and am currently @ 1.47 vcore and 3.8ghz. With prime 95 (full load) I get 55 degrees Celsius max temp. I would like to get 4ghz but I'm not sure what to do next. I am using a hyper 212 + (with arctic mx-2 thermal paste).
If you guys could help me reach the magical 4ghz that would be awesome, but it does seem like 3.8ghz is as far as my processor will go. It's also a c3 stepping if that helps.
EDIT: Scratch that, I just crashed while stress testing, I've had to bump the voltage too 1.48v. Hopefully that will be stable.
Also it seems people are managing to get quite high temps with hyper 212 plus http://www.overclock.net/amd-cpus/499526-official-phenom-ii-x4-9x5-oc.html . Should I try changing settings other than the voltage and the multiplier?
