Tom's Hardware > Forum > Graphic & Displays > ATI > [Solved] Driver Problems
Best answer from 505090.
If I have an NVIDIA chipset and use a ATI PCI-E Graphics card will I have conflicting NVIDIA ATI driver issues?
IS a ATI RAdeon 4670 good?
------------------------------ Teamwork is essential; it gives them other peope to shoot at.
should work fine
Sponsored Links
Best answer
should work fine
------------------------------ E8400 : GA-EP35-DS3L : mushkin 4GB DDR2 800 : HD 2600PRO : 450W ATX12V : Windows 7
Reply to 505090
Should work fine, just remember to uninstall the NVidia device drivers, then disable the on-board video in the BIOS before installing the ATI, but you probably already knew that. 25 cents please...lol
Reply to mikey5802
xp can actually run both nvidia and ati drivers at the same time, unlike vista. Not sure about win7 but since it's based on vista I would assume not.
Reply to 505090
There are 1225 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
