Tom's Hardware > Forum > CPU & Components > CPUs > Help!!!! I think i did something WRONG!? *about unlocking*
Forum CPU & Components : CPUs - Help!!!! I think i did something WRONG!? *about unlocking*
Ok basically i wanted to see if the 4 core would work since i have 550 BE and i did the ACC and EC firmware thing but then it booted and i was like :bounce:
literally :P
but in cpu z it says i only have one core now :cry: help please did i do something wrong?!
Sponsored Links
literally :P
yea you bought a dual core if you wanted a quad you should have bought one or at least do your homework before you try unlocking cores.
Reply to ericpol
Congrats, you got one that was disabled for a reason. Turn off ACC and it should be back to normal. Some of them were disabled because they were slightly off, some of them were disabled because the two cores were totally defective, i bet you got the latter.
Reply to hunter315
dang and i was so happy that it worked :(
nice quote btw :P
Reply to killa4lyfe
There are 497 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
