Well, I just finished and booted up my first pc that I've built! I'm now searching around in the BIOS for RAM settings. I have 4GB of G.skill ripjaws 1600mhz RAM (1.6v) ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
.. installed with an i5 750 cpu on an Asus p77p55d-e pro mobo. I know I can only run these sticks at 1333mhz with my cpu right? Is it ok if I manually select 1333mhz as the DRAM speed option in the BIOS? I believe it is now set to AUTO. I do not want to change anything without being sure. Also, where do I see the voltage of the installed RAM? This RAM is suppose to be at 1.6v. Should I change anything if it is not at 1.6v? Can I make it any better without hurting anything? Where is the voltage setting?
The CAS settings for this RAM is 7-8-7-24-2n. I believe I saw in the BIOS that it is currently running at 9-9-9-something. Can I mess with these settings? It looked kind of confusing to try and change those. Now I bought this good RAM and I want it to run as good as it can without hurting it. How do I go about making it run at 7-8-7-24-2N???
Sorry for all of these questions but I am a BIOS nOOb! I want to learn how to change things myself and make my system run as well as it should. I'm gonna hold off on overclocking the cpu right now but I would like to get my RAM up to speed ASAP.
Any info would be appreciated.
Thanks for your time!
- manooly
- manooly
