Having an issue with this new build, basically the system doesn't power up past a two-three second spin of the fans. I've swapped the mobo with an identical one, put a new PSU in, removed the memory to try and at least get a post beep. I pulled the board out and tried just out of the case to make sure it wasn't an issue with one of the chassis mounts or a short or something.
I'm scratching my head, I'm RMA'ing the CPU back to newegg now as it's the only thing I haven't ruled out and left at this point. My biggest fear is my new CPU will get here and I'll have the same exact problem.
Tried with various combos of this hardware
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750
GIGABYTE GA-H55M-UD2H LGA 1156 Intel H55 HDMI Micro ATX Intel Motherboard
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3OB1600LV4GK
GIGABYTE GV-R467ZL-1GI Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
FSP Group Blue Storm II 400 400W ATX 2.2 Active PFC Power Supply
ENERMAX ECO80+ EES500AWT 500W ATX12V V2.31 SLI & Crossfire Ready Compatible w/Core i7 80PLUS Certified w/Magnetic Magma Fan Active PFC Power Supply
