Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] 3d mark 06, 05,03 wont run ??why??need help...
Forum CPU & Components : CPUs - [Solved] 3d mark 06, 05,03 wont run ??why??need help...
Best answer from jennyh.
i just bougt a new computer last week..
my spec's :
Phenom II X4 955
MSI 770-C45
Sapphire Radeon 4890 Vapor-X
G-Skill 2gb DDR3 12800 C9
Seagate 500gb
LiteOn DVDRW
Xigmatek NRP-MC651
CM-Strom Scout
vista ultimate 32bit was installed...
when i try to install and run 3DMark06,05,03 it just wont start...
the spalsh screen is showed up but when it's time to appear the main window it just wont showed up,, in task manager-not responding..
the 3Dmark06,05,03 was smoothly work on my laptop's and friend's pc and laptop... if i'a not wrong it was 1.1.0 version
why it just happen??? when i want to benchmark my pc.... how i can fixed that problem.....?????
tanx 4 the help..
Make a shortcut to 3DMark06 on your desktop - easiest way of doing this is by right-
clicking on 3DMark06 in the Start Menu and going to the "Send To" part, choosing "Desktop".
Right-click on the desktop shortcut to 3DMark06 and choose "Properties"
Add -nosysteminfo after all of the contents in the Target box - so it looks something like this:
"C:\Program Files (x86)\Futuremark\3DMark06\3DMark06.exe" -nosysteminfo
Run 3DMark06 without the system scan!
copied from some old thread on the web, seriously can't you google this stuff?
Sponsored Links
Best answer
------------------------------ AMD to make $1.5bn profit Q4, *gauranteed*
Reply to jennyh
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
