Intermittently, for the past 8 months, I have been trying to solve a sound stutter/computer pause problem that would occur randomly when taxing the system. Setting WOW graphics to Ultra would set it off more often but it even occurred occasionaly while watching youtube. After searching google, downloading current drivers, over and over again, tweeking bios settings, and cursing Vista I have finally resolved the problem. So for you who are still struggling with the problem, this is the solution.
Do not use the 2 purple gigabyte sata ports. Plug all your sata drives into the other six standard sata ports, and disable the gigabyte sata ports in the bios.
Now my EMU 1212M PCI sound card works perfectly with no stutters or computer pauses and WOW works perfectly with all the video effects maxed out. I also have the Realtek Azalia audio enable but I don't use it.
Finally, the machine is stable.
