Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > External USB 3.0 HDD Problem
Forum Storage : Hard Drives External USB 3.0 HDD Problem
Myself and a friend of mine each have a verbatim Superspeed USB 3.0 external hard drive and we also have a Del XPS laptop with USBs 3.0. The problem we have is when we plug the drive into the laptop it will continuously inform you to format the drive first. Over and over like it keeps finding the drive. I have called Verbatim tech support and was told to find on the web the NEC USB 3.0 driver that this should fix it, well it didn't. If I hook it up using a USB2.0 cable it works fine. My friend has also been in contact with dell tech support and hasn't been able to fix the problem. Any suggestion, what to do?
Reply to tennek
well.... HAS the drive ever been formatted?
every single time you log on it would most likely pop up.
i know that some hard drives most likely come pre-formatted if they have tools installed on them (like some major brands do) but i'm not sure about the verbatim brand drive.
if there is absolutely nothing on the drive, then perhaps yes, you might need to format it.
Reply to ssddx
yes it has been formatted, though the only way I could was by using a USB 2.0 cord
Reply to tennek
Reply to tennek
There are 2016 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
750GB 7200RPM 16MB Cache vs. 640GB 5400RPM 8MB Cache
By Truckinupga, 10 hours ago:
Pay the extra 50 and get the 750GB, Not only for the extra space but the larger cache and...
Best offers
Top experts
