i had a CRT monitor which is yellow on its display. so i bought a new one as a replacement. i bought new LCD monitor last week. but still, the symptoms of becoming a yellow on screen display occur. what is the reason it happened? please help..
Sponsored Links
Did you replace the VGA cable? otherwise it sounds like the video card may be damaged. Need a few specs, ie motherboard info. does it have an: AGP, PCI-X16, or just PCI slots.
Reply to IH8U
GPU: discrete or integrated?
Have you tried using other cable?
Reply to masterjaw
i used the new VGA cable that is included in the package of the new LCD monitor.. i also used the built-in video card of the motherboard.. yes, it have an: AGP, PCI-X16, or just PCI slots.
Reply to bntejada
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Monitor problem?
There are 1249 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
