Solved
AMD phenom II X2 555 unlocking .. PROBLEM
September 8, 2011 8:31:46 AM
I got this processor up in the title and i tried to unlock the 4 cores but somthing strange had happened
when i try to unlock them it freeze WHILE I AM IN A GAME i know it`S unstable but when i tried to close the 4th core and
make it 3 cores only or triple core it works without any problem (i thought the 4th core defected so i closed it)
i tried yesterday to close the 3rd core and make 1,2,4 are active cores it works great
the question is i thought that th 4th core is defected but when i included it with my other 2 cores it works how on earth this happened?
I mean i hadn`t a core defected then???
how can i make 4 cores available if there is no core defected
SPECS
MOBO:ASUS M5A97
VGA:SAPPHIRE 6950 2GB GDDR5
PSU:GAMMA 500 WATT
MEM: G-SKILL 4GB 1600 MHZ
Best solution
a b à CPUs
September 8, 2011 8:54:42 AM
Well, it could be that the CPU has a problem in the interconnects between core 3 and 4. So that if they are both enabled they will cause an instability.
Also, it could be a voltage issue, maybe the voltage is not sufficiently stable with 4 cores running, or crosstalk internal to the chip.
It could be anything like this, and there is no realistic way to find out that I know of.
You should be happy you got a free core out of it and leave it at that IMHO.
September 8, 2011 9:03:08 AM
Best answer selected by the elve.
m
l
September 8, 2011 9:04:16 AM
thank you at least i got 1 free core as u mentioned but
the problem is i got terrible frames with this cpu
m
l
September 11, 2011 7:37:31 AM
Dude your 500watt PSU is NOT enough i had a 500 watt with a 6850 asus and had the same issues upgrade your power supply to 650 or more and you wont have anymore problems
m
l
