http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
Well thats my case, now the question is, would I be able to fit a liquid cooling system completely inside?
I use an h50 which takes up the back 120mm fan. So I was thinking of a dual 120mm radiator on top. Then I got stuck, as to where to put a pump / res etc. My single 6870 gets hot enough (80C under load) And Im going to add another one around xmas so the temps are going to get higher. So yeah, would a cooling system fit inside here?
