New To WaterCooling (Looking for tips and help for choosing my parts)
Hey There So i was in the market to buy myself some watercooling kits for my computer. But i dont know where to start, I've checked online at different water blocks, different tubes, Radiators, etc etc. But Im stuck in figuring what would be Best (and if possible CHEAP) for my system.
Im only looking to water cool my CPU, and 2 GPUs. My Set up and rig is this.
CPU: AMD 1090t 6 Core Black Edition @ 4 Ghz (~60C full Load)
MOBO: Asus Crosshair IV Formula
Case: HAF 932 Full Tower (Original Edition)
GPUs: (1) Asus ATI Radeon HD 6950 (2GB Vram) & (1) HIS ATI Radeon HD 6950 (2GB Vram)
Power Supply: Thermal Take Black Widow 850 Watt
RAM: 8GB G-Skill 1333 Mhz
CPU Cooler: Thermaltake Frio
I just need advice on what i should buy and get, and any tips to make it fit right in my case I know alot of you out there also have the HAF 932
Thank you :)  ;)
'ONLY' your CPU and 2 GPUs? That's a lot of heat watts in a loop...you are going to need some good radiators (yes, multiple) and pump. What kind of blocks? Reservoir?
What is your budget? Just FYI...you are looking at about $300-$400 for a relatively conservative budget unless you go used.
Have you read the sticky? I have it linked in my signature below.
For installation ideas...http://lmgtfy.com/?q=HAF+932+water+cooling
Ask the community
