Tom's Hardware > Forum > Graphic & Displays > ATI > HD 4870 Power Question
Forum Graphic & Displays : ATI - HD 4870 Power Question
I'm looking to upgrade my current video card (currently running HD 2400) and I really like the HD 4870's specs, my only concern is the power supply recommended is 500W minimum. I'm currently running at 450W. Another issue is the 2 6 pin PCI-E connectors, but I know I can run those with a couple of conversion cables from some Molex connectors. My question is: can I run the HD 4870 with my current PS or am I looking at a power supply upgrade as well if I go with that card?
My 2nd choice would be the HD 4850, which would work with my current power supply, and only requires 1 6 Pin connector. I'm just wondering what the performance difference is between the 2 cards.
I typically only play EverQuest 2, and Half Life 2, so I'm looking for something to get the best experience out of those games.
The rest of my rig is: Duo Core 2.4 (OC to 3117), 4 Gig RAM
Sponsored Links
what is the make and model of your PSU? If it has enough amps on the 12v it should be ok.
------------------------------ Recipient of multi-best answer awards and $3 power ball winner!!
Reply to ct1615
- 0 +
It's a ChiefMax 450W ATX Switching Power Supply. With the right conversion cables to convert 4 Molex connectors, would this power supply be enough to run the HD4870?
Power Supply: http://www.chiefmax.com/psu/cm450-24pin.php
Reply to liftik
You'll be okay that psu will run it!
Reply to area51reopened
There are 1131 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
