Cooler Master 840 ATCS Project
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Cooler Master 840 ATCS Project
I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
I should know by first week of November what hardware CM will be sending me.
http://www.mnpctech.3dpixelnet.com/picture_library/district9.d9.casemod.mnpctech.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9.d9.casemod.mnpctech.com4small.jpg
Conceptual drawing by E.E.L. Ambiense
Case Mods & Supplies used in this project by Mnpctech.com
Machined Aluminum Computer Case Feet Link
http://www.mnpctech.com/computer_feet_machined_aluminum_mnpctech.com1.jpg
Acoustical Sound Proofing Sheets for your PC
http://www.mnpctech.com/acoustical_pack_foam_pc_soundproofing_grey_sheets1.jpg
Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
http://www.mnpctech.com/colored_ac [...] indow.html
http://www.mnpctech.com/clear_acrylic_sheet_casemod_mnpctech.com1.jpg
This is the Honeycomb Modders Meshwe used.
http://www.mnpctech.com/ModdersMesh.thm.jpg
PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
The canvas for this PC build is the Cooler Master 840 ATCS
http://www.mnpctech.3dpixelnet.com/picture_library/coolermaster_840_ATCS_mnpctech.com4.jpg
Adding window to Cooler master 840 ATCS
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_pc_casemod_mnpctech.com4.jpg
Using tape roll to make curved corner
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_pc_casemod_mnpctech.com5.jpg
Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com6.jpg
You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
http://www.mnpctech.3dpixelnet.com [...] h.com7.jpg
http://www.mnpctech.3dpixelnet.com [...] h.com8.jpg
Using a Jigsaw is much quicker than using a Dremel to cut your window
http://www.mnpctech.3dpixelnet.com [...] h.com9.jpg
Message edited by MonsterMawd on 10-29-2009 at 01:24:52 PM
Sponsored Links
Use a rounded side file to debur the jagged edges of the new window
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9a.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9b.jpg
Notice the window location doesn't reveal the drive bays, this was intentional.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9c.jpg
Reply to MonsterMawd
Upgrading the 840's stock 120mm exhaust fan to 140mm fan.
Cooler Master 840 ATCS rear 120mm exhaust
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9g.jpg
I'm holding up a 140mm Cooler Master fan over the stock 120mm grill. "Will it fit without anything obstructing it?"
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9h.jpg
The location of the 140mm fan resides along the crease on the back plate.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9i.jpg
Making the initial cut with Rotary tool and reinforced cutting wheel before using Jigsaw
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9i2.jpg
Using Jigsaw with 18 TPI metal cutting blade
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9j.jpg
Using rounded side hand file to clean up burrs along the edge of the cut.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9k.jpg
140mm opening is cleaned up, next is drilling mounting holes for 140mm fan
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9l.jpg
vibration dampening fan grommets
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9q.jpg
Using a 1/4" size drill bit to make the mounting holes, this allows the fan grommets to fit.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9p.jpg
Vibration dampening fan grommets installed.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9r.jpg
I really like the F-150 pick-up from District 9
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9s2.jpg
For the exhaust fan grill, I cannibalized an early Monsta Rad grill prototype we made this year.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9s.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9t.jpg
We've cnc milled the "District 9" design in the Cooler Master 840 aluminum intake plate. The recessed center portion will be the CM case badge
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.comfg.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9d.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9e.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9f.jpg
I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
The window will be fastened with 1/4" socket head screws, for reinforced armour look
Using center punch to mark each fastener hole.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9x.jpg
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new)
http://www.mnpctech.3dpixelnet.com/images/pics/SilentSwing9etool.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9y.jpg
"Look Ma, No deburring needed!"
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z.jpg
The benefit of using Lexan is that you can drill or hand punch it without cracking it.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z2.jpg
Clean hole cut! I love Lexan.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z3.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z4.jpg
Ironically our concept drawing calls for bullet holes in the Lexan "bullet proof" window...lol
Cooler Master's hardware list for their CES show display
1 x Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
1 x Intel Extreme Series DX48BT2 X48 Motherboard
1 x Silent Pro RS-600-AMBA-D3
1 x CM MITX Cooler 38mm tall (will be replaced with future V series cooler)
1 x Sapphire ATI Radeon 4870 512MB
1 x 4GB DDR3 Kingston 1600mhz memory kit
1 x WD 500GB HDD
1 x DVD drive
Silent Pro RS-600 Watt-AMBA-D3 PSU
http://www.newegg.com/Product/Prod [...] 6817171036
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z6.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z8.jpg
Are you a fan of the Black Ribbon power cables?
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z8a.jpg
The concept called for bullet holes in the window
Using 3/8" drill bit
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9c.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9d.jpg
Using wire cutter to make cracks around the hole
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9e.jpg
Etching Rotary Tool (or Dremel) Engraving Bits
http://www.mnpctech.3dpixelnet.com/picture_library/homermod.acrylic_etching9s.jpg
Using the dremel to emulate some cracks
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9f.jpg
I'm adding bullet holes to the case too, so I drilled holes in the 840's aluminum panel. I then used a tin snip and needle nose plier to cut and rip the 3/8" hole open
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9g.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9h.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9i.jpg
CM is planning to show their new V-series cooler, they wouldn't reveal the model to me. I may rig a Cat Food can as cpu cooler, just for joke when they open the case....lol Cooler Master only sent 1 hard drive, so no sense in keeping the HD bay!
Use 1/8" drill bit to remove HD bay
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9u.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9v.jpg
1/4" thick acrylic sheets will act as reinforced segments of the side panels.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_concept3.jpg
Heres a close up of the vertical blade cutting 1/4" acrylic sheet
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9m.jpg
These edges are not acceptable
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9n.jpg
Black & Decker Mouse Sander with Medium grit sandpaper
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9o.jpg
Thats better!
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9p.jpg
Starting on other side tonight, this side still needs exploded hole, and I need to get more 1/4" socket head screws. Those will be countersunk
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9q.jpg
wow. Thats alot of work for a case mod. But very nice craftsmanship. I like
Reply to pathasse
i would be scared to crack that lexan
Reply to pathasse
Thank you, you should wear safety glasses. I can't cover up the bullet holes..lol
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9y.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z.jpg
I used the Dremel with a cutting wheel to emulate impact to the reinforcement panel.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z1.jpg
Using Dremel with egraving bit to gouge the other bullet hole under the acrylic. A ventilation hole was added as well.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z2.jpg
Round Modders Mesh used as the ventilation grill in the left side panel.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z3.jpg
Scotch Weld DP-190 2 part epoxy is used to attach the Modders Mesh to the backside of the side panel
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z4.jpg
Mwhahahah. I love cutting nasty holes in a nice computer cases.
Something exploded in Christopher's computer at one time. He never bothered fixing the hole.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z5.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z6.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z8.jpg
1/4" thick White acrylic sheet with District 9 sign will be the grill for 2x 200mm top fans
We cnc milled the grill, but If you have custom laser cutting needs, I suggest contacting http://www.vintagelaser.com
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9r.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9s.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9t.jpg
Today I worked on the acrylic plates for the right hand side panel. I used the barrel engraving bit to create cracks around the hole.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9a.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9b.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9c.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9d.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com9z9z9e.jpg
Here is some screen shots taken from the movie trailer on Youtube. I think it's important to have the prawn canister implemented into the case. If Cooler Master had requested watercooling, it would been fun to make a reservoir based on the canister, but the system will be air cooled. We have some 2" diameter solid rod on hand we could use to re-create something close to it. I have some ideas, but want to have it my hands first before I commit to them.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn2.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn3.jpg
These are the diamond knurl machined aluminum case feet shown in the original concept. The 840 comes with feet, but these fit the industrial theme. The only modding necessary was drilling out the existing threaded holes with 3/16 drill bit for 8/32 screws included with diamond knurl feet.
Diamond Knurl Computer Case Feet
http://www.mnpctech.com/Aluminum_C [...] _Feet.html
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet2.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet3.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet4.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet5.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_feet6.jpg
Thanks Johnny! 2" diameter aluminum rod. The Prawn canister will illuminated from inside, and located in the 5.25 drive bay
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn4.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn5.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn6.jpg
Started on the paint last night, White and Orange segments
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint2.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint3.jpg
The "Pumpkin" Orange color was done first. The perimeter of the " exploded hole" will be airbrushed with a burned surface effect
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint4.jpg
The Cooler Master 840 chassis painted with Semi-Gloss White
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint1.jpg
Thanks for comment! Once everything is assembled, all of the details like weathering, graphics, and effects can be airbrushed on the exterior like the concept drawing.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_handle1a.jpg
Left side panel, the hole will have burned effect airbrushed on later
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint5.jpg
Right side panel
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint6.jpg
Cooler Master sent over 3x 230mm red led fans, 1x for front intake, 2x top exhaust
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint8.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9.jpg
The 840 normally comes with Black frame 230mm fans, no leds.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9a.jpg
I've had this .5" x 25" flexible conduit lying around, I've always wanted to use it for routing cables. It fits the industrial theme. I've also got .25" i.d. flexible conduit.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9b.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9c.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9d.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9e.jpg
I like the flexible conduit. Never thought of using metal conduit. I got some "chrome" flexible plastic conduit at my local Fry's Electronics store for a case mod last year. Last night I was at Home Depot and spotted black flexible plastic conduit dirt cheap. Would be great for a case with an all black interior.
------------------------------ Intel Core i7 860 | Asus Sabertooth 55i | G.Skil ECO DDR3 1600 | XFX 4770 | Thermalright Venomous-X | WD Caviar Black | Plextor dvd | Seasonic X650 Gold | Lian Li Dragon Lord case
Reply to JohnnyLucky
I agree, and have used it Johnny. I'm working on a HR GIGER biomechanical theme PC and used it on the bezel,
http://www.mnpctech.3dpixelnet.com/picture_library/radgrill.radiator.install.mnpctech.com9z9sz9c.jpg
Here is the Prawn canister from the movie.
My canister will be lit with a 4" UV cold cathode, mounted on the inside wall of the back cover.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9h.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9i.jpg
Once it's painted and the window is darkened a bit, it should look eerie.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9j.jpg
canister back cover
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9g.jpg
for canister window, I'm going to bend a piece of clear 1/8" thick case acrylic with a heat gun, but more on that later!
http://www.mnpctech.com/acrylic_co [...] dows1.html
Wow.... nice work. Btw, what did happen to the biomech case? Anyways, wish CM ordered a WCed PC. That canister would have made a perfect res, and would have been awesome with a tornado effect.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
I'm still looking for sponsorship of MB / CPU for that build.
I made the canister's window today. Using a heat gun to bend the Lexan.
Forming the arc in window by pressing heated piece on the Aluminum rod. It's HOT!
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn8.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9a.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9b.jpg
4" UV cold cathode.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV1a.jpg
UV looks Blue in the photos
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV2.jpg
The window will be painted to look murky, like the original canister
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV3.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV4.jpg
The canister will be painted tommorow
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV5.jpg
That canister looks sick! Btw, where did you get that Aluminum block for the canister?
Thank you, It was 2" rod stock we had here already.
Orange Bezel with White intake plate installed. I cannot wait to grunge it up!
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV8.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canistorUV9.jpg
MM, just took a look at the case mod store, would you guys happen to have any radiator fan grills for 420 rads?
No, but you can find them at performance-pcs.com Shadow :)
I chose the 1/4" socket head screws, these are fastened into the side panels
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9c.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9d.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9e.jpg
Looks amazing !
Very nice job. Love it
Reply to omgitzfatal
Thanks! The Prawn canister can't remain Silver. I prepped the aluminum surface with medium grit sandpaper, applied Black SEM self etching primer, then headed over to Brad's so he could apply the Pewter base color coat. Brad did all of the Prawn canister graphics by applying vinyl film and cutting the designs free hand with an Exacto, he used the movie still for reference. Look Ma, No vinyl film plotter or software! http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com2.jpg
Prawn canister window was tinted like original
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com3.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com4.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com5.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com6.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com8.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com9.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_D9_canister_prawn_mnpctech.com9a.jpg
http://www.mnpctech.3dpixelnet.com [...] .com9b.jpg
Quote :
Now THAT'S just skill and balls. A small mistake could have ruined a lot of work....
Anyways, thanks for the link, but there's only 4 or 5 grills for the 4x120 rads :cry: and non of them are exactly what I wanted. Looks like I gotta make on my self....
D-i-y dude! :)
While at the shop last night I cut some 1/8" thick mirrored acrylic sheets to encase the 5.25 bay around the canister location.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9f.jpg
I used the Scotch 4010 Heavy Duty Tape to adhere onto the mirrored acrylic
http://www.mnpctech.com/scotch_401 [...] _gods.html
http://www.mnpctech.com/4010scotch3mtape.mnpctech.com.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9h.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9g.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_canister_prawn9i.jpg
RUSTED GPU!
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9k.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9l.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9m.jpg
Watch E.E.L. Embiense demonstrate how to use the Sophisticated Finishes products for adding a rust effect to your Mods.
http://www.youtube.com/watch?v=26Ud9T-doAc
I think Christopher left his scrap PC out in the rain a few times. To create those results, I apply the Iron Surfacer to the top panel first, then the Rust Solution after 10 mins. I repeated these steps over different locations on the exterior. The more Rust Solution you apply, the more Orange colored effect you get.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust2.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust3.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust4.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust5.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust6.jpg
AW GEE! I liked the pretty colors and now you go and grunge everything! :)
pretty colors + rust = cool
There will be an MNU logo painted on this optical drive. Christopher likely traded something towards it, so he could view cd rom archived files from MNU perhaps?
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust9a.jpg
More rust effects occur..
The new 600W Cooler Master Silent PRO didn't look right in a POS computer, it was treated to "rust lovin" as well.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust9b.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust9c.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_rust9d.jpg
Quick question, according to copyright,etc laws can you actually use all these logos,etc from the film on a project like this?
Anyways, great work, but I personally don't like that "rust" color?
Message edited by Shadow703793 on 12-17-2009 at 06:59:09 PM
District-9 is a dirty place. I would have a hard time imagining this looking pristine.
Intel Core 2 Duo 3.16 GHz Processor in Intel DX48BT2 Motherboard sent from Cooler Master.
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_system1.jpg
I'm looking at this Cooler Master HYPER N620 and wondering ""What Christopher do differently with it?"
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_system2.jpg
I wanted to direct the cooler air entering the front of the case to the cpu cooler. The 5.25 bay covers were removed to highlight the canister movie prop we made. It dawned on me that a fan duct could be mounted to a 120mm fan by modifying a 120mm round mesh fan grill. In the past, I would mold the fan duct into the front bezel with body filler, but this method is much easier and more versatile.
This method can be combined with 4.5" flexible tubing to isolate cool airflow. Imagine one end of the tube attached to a 120mm cooling fan in front of your case.
The 4.5" Flexible tubing can be found at Mcmaster, http://www.mcmaster.com/#duct-hose/=4zltce or you can "try" the "Heating & Cooling" department at hardware or home improvement stores like Home Depot or Lowes.
Supplies & Tools:
120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html
4.5" fan duct, http://www.mnpctech.com/FanDuct.html
4, #10 x 5/8" fan screws, http://www.mnpctech.com/thumbscrew.html">#10 x 5/8" fan screws</a>
120mm cooling fan.
Paint pen or pencil.
Tin snips.
Wire cutter.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu1.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu2.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu3.jpg
Using a paint pen to trace the duct onto the round mesh grill.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu4.jpg
a small wire cutter and Tin snips used to cut the 4.5" opening in the 120mm Modder's Mesh Round fan grill
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu5.jpg
You'll need to use the small wire cutter first, to make the initial cut before you can use the Tin Snips to cut the 4.5" hole.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu6.jpg
Using Tin ship to cut the round mesh grill.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu8.jpg
The result of you cutting should look like this.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu7.jpg
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu9.jpg
120mm cooling fan. This fan has enclosed corners, you will need longer fan screws if you're mounting the fan onto something like a cpu cooler.
http://www.mnpctech.3dpixelnet.com/picture_library/120mm_fan_air_duct_cpu9a.jpg
4, http://www.mnpctech.com/thumbscrew.html, #10 x 5/8" fan screws</a>
http://www.mnpctech.3dpixelnet.com [...] _cpu9b.jpg
http://www.mnpctech.3dpixelnet.com [...] _cpu9c.jpg
http://www.mnpctech.3dpixelnet.com [...] _cpu9d.jpg
Yesterday I painted the 2x 120mm cooling fans from the Cooler Master HYPER N620, will post those photos soon!
140mm Aerocool Fan for the exhaust, was also painted Matte White
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9n.jpg
Fan Grill made from Round Modder's Mesh, http://www.mnpctech.com/moddersmesh.html
http://www.mnpctech.3dpixelnet.com/picture_library/district9_d9_coolermaster_840_casemod_mnpctech.com_paint9o.jpg
Love it!
Did you consider using the patina finish kit from Sophisticated Finishes in addition to their rust finish kit?
Reply to bwilson420
^ That's a good idea!
@OP: Do you know where I can get 24x24" modder's mesh? The largest I'v seen is 24x12". After seeing your work here and other places, I thought I'd do a custom case too: http://www.tomshardware.com/forum/ [...] s#t2029305
Previous
1 2
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Cooler Master 840 ATCS Project
There are 886 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
