I'm doing a new build, after looking at my fan orientation I think I might have some sort of air turbulence.
ATX Mid Tower Case ( http://www.ultraproducts.com/applications/searchtools/item-details.asp?EdpNo=186334)
This case will have a 80mm fan in the bottom front.
I'm planning to use - Noctua NH-C14 as the CPU Cooler (http://www.newegg.com/Product/Product.aspx?Item=N82E16835608020) two fans which can either blow to the mobo or away from it.
The back of the case will have a 120mm fan.
So air enters the case from the front using the 80 mm fan; then the air gets pulled towards the cpu (2600K), and then air gets out using the 120mm.
Noctua NH-C14 was ranked 2nd in Frostytech, like to stick to it, except the air flow is giving me some concern.
Choice 2:
My other choice is to use Noctua NH-D14 cpu cooler (http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018&Tpk=Noctua%20NH-D14).
In my mind the air flow from the front fan to the two fans of Noctua NH-D14 and then to the rear fan may create a smooth flow of air.
Noctua NH-D14 was rated 4th by Frostytech and its bigger than Noctua NH-C14, my case can accommodate both the heatsinks.
I'm new to building, can some experts suggest which heat sink would give optimal air flow.
Choice 2:
