I've got two EVGA 570s that each have two fans in them and a side panel I'm planning to mount a fan in that will be almost right over these 570s (oops--to the side of them). I haven't read or looked to find whether the four 570 fans will be drawing air in across the heatsinks or blowing air out--for case fans I'm not sure it matters--that is the question... Should this side panel fan be blowing outside air in or drawing warm case air out??
And related perhaps... For best cooling effects should I strive to set up positive, neutral, or negative pressure inside the case?
I do not plan at this point in time to overclock. As it stands I will have four case fans with the plan to draw air in from the front panel fan; exhuast air out from the rear panel fan; draw air in from a top fan to assist cooling across the DIMMs and CPU fan/heat sink; and then which way to go with the side panel fan?
With two other fan locations open and unused--one on the case bottom and the other being a second fan on top plus other vent locations in the case I don't see how I will end up with too much pressure diferential between inside and outside.
Thank you for your theories/advice.
