Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > HD 4670 vs 9800 gt low power in dell e520
Forum Graphics & Displays : Graphics Cards HD 4670 vs 9800 gt low power in dell e520
pentium d 2.8ghz,
2.5gb ram,
dell e520 305w stock cpu
windows vista home basic &
dell 21" monitor....
9800 gt: http://www.newegg.com/Product/Prod [...] 6814162032
hd 4670: http://www.newegg.com/Product/Prod [...] 6814102818
will the 9800 gt bottleneck my system????
if yes..............................................
will i get best from hd 4670 or with 9800 gt????
if no...............................................
will it play gta 4 in medium....
gta 4 is the coolest game eva..
Reply to babydevil05
You could probably run a 9800 but the 4670 is the best match for the rest of the computer. Your CPU will most likley restrict either but i would not let that bother you.
Mactronix
Reply to mactronix
Mactronix
but which one will i get more fps, 9800 gt or 4670??????
9800 will get more FPS but also consume more power. More than I would recommend for your weak PSU.
The HD 4670 consumes about 48w of power while the 9800GT consumes about 85w. Pretty significant difference for a 305w PSU.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
9800GT will give more performance overall.
Both will be bottlenecked by your CPU.
For GTA 4 both the cards are good enough. But the real problem is your CPU.
Even nice core 2 Duo's struggle to play GTA4.
I will suggest you to buy the 9800GT.
Reply to shubham1401
- 0 +
do some research before you post, are leave the boards and rid us of your stupidity!
the Dell 305w PSU has enough amps on it to run a standard 9800GT. Many Dell users have run the standard 9800GT and ATI 4830 on that PSU. In fact that "weak PSU" has more amps then most generic 400w PSU. The 9800GT EE is make specifically for a generic 300w PSU so you will have no issue what so ever running it and I would recommend that card over the weaker 4670.
------------------------------ defeating idiot fan boys since 2008.
Reply to ct1615
- 0 +
Reply to ct1615
will it be a little bit overkill if it the 9800 gt is 1gb.....
the shop have 1gb only, at $115 (RM410).....
& how much $$ will i save if using 48w rather than 85w...
im a f'ing noob at this...
wakakakaka
Message edited by babydevil05 on 08-21-2009 at 06:36:56 PM
There are 1947 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help appreciated
By 2fast4thetown_down, 2 hours ago:
If you have a 400 or more psu you should be fine it seems to be compatable just look at...
Best offers
Top experts
