T turbocookie Distinguished May 4, 2011 8 0 18,510 Sep 11, 2011 #1 I cannot find a way to monitor my pc case fans, im using the antec 902 gaming case, stock fans still. 4 pin connector fans with adjustable speeds.
Solution ko888 Sep 11, 2011 Are your fans the original ones that came with the Antec 902? How may wires are connected to each of the 4-pin connectors for each fan? If the fans have only two wires (red/12V and black/ground) connected to them then there is no way to monitor their speed. The white wire (speed sensor/tachometer signal) is required if you want to monitor the fan's speed.
ko888 Titan Feb 18, 2009 16,708 41 84,990 Sep 11, 2011 Solution #2 Are your fans the original ones that came with the Antec 902? How may wires are connected to each of the 4-pin connectors for each fan? If the fans have only two wires (red/12V and black/ground) connected to them then there is no way to monitor their speed. The white wire (speed sensor/tachometer signal) is required if you want to monitor the fan's speed. Upvote 0 Downvote Solution
T turbocookie Distinguished May 4, 2011 8 0 18,510 Sep 14, 2011 #3 Ah ok, thankyou, yes stock fans from case. only two wires, but with 4 pin connectors. Upvote 0 Downvote
T turbocookie Distinguished May 4, 2011 8 0 18,510 Sep 14, 2011 #4 Best answer selected by turbocookie. Upvote 0 Downvote
