Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Motherboard, power supply or hard drive?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Motherboard, power supply or hard drive?
My first guess would be the power supply but i've never seen a power supply die like this before. I was in the middle of working when all of a sudden the computer died. I tried to reboot and i hear the PS fan start, hard drive light will light up but no hard drive tick and dvd checks itself. After all that, nothing. No fans, no MB light, no vid card so no monitor boot out of it's standby. If any of this sounds familiar or you could throw some much needed knowledge my way, it would be greatly appreciated.
Message edited by Anonymous on 10-28-2009 at 01:12:24 PM
Sponsored Links
If you can borrow a ps from another system, try that first. If not, check newegg, ebay or computer geeks for motherboard and ps pricing, and decide if they are worth replacing. If you can find a board with the same chipset, you may avoid a format, depending on which operating system you have.
Reply to o1die
Killer deal on a killler psu. 2- 25a rails, 82% efficiency, PFC, modular cables.
http://www.newegg.com/Product/Prod [...] 6817341022
Message edited by zipzoomflyhigh on 10-28-2009 at 12:32:30 PM
Reply to zipzoomflyhigh
Try reseating the CPU or another video card.
------------------------------ GA-EX38-DS4 | E8400 @ 3.6 ghz - Hyper TX2 | 2x2G Patriot Extreme DDR2800 | GeCube HD3870 OC Ed. CF w/Sapphire HD3870 | Vista Home Premium 32 | Antec SLK-3800B Case | Corsair 650TX PSU
Reply to myriad46
Take it to a dealer and check the psu!
Reply to Aneesh@4GHz
There are 597 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
