I am using the stock fan and heatsink. The case also has decent airflow.
Room temp is 24C IDLE CPU--28C
MOBO--34C
NB--37C
HD--38C LOAD (running prime95 for 40min) CPU--42C
MOBO--36C
NB--48C
HD--39C
On a completely seperate system. Same budget though ($40-$80).
I am looking for a high end FAN and HEATSINK to cool an i5 running on this motherboard http://www.newegg.com/Product/Prod [...] 6813130238 I don't really want to get into water-cooling, but i saw this http://www.newegg.com/Product/Prod [...] 6835181010 would it be able to cool the i5 better than a high end air cooler??
This system also has a case with great airflow http://www.newegg.com/Product/Prod [...] 6811119194
Message edited by kylo on 10-28-2009 at 08:37:41 AM
Heres a look into a cooler review done by Benchmarkreviews.com. Tho this was for an i7 1366 test setup, you should see similiar results with i5 1156.....
