Will this RAM work in my build?
With the help of a few community members I put together a fairly cheap/powerful build. I am ordering Monday and continuing throughout the weekend to check prices on the items. The core being:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.211975
(Mobo/GFX Card)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.205073.19-103-674
(Processor/OS)
Will this RAM work with the mobo?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231259
The pin matches (240) but I don't know if the SDRAM portion matters or not (excuse my lack of knowledge, google does not help). If so it is a good choice for the price?
4 answers Last reply
More about will work build
  1. Yes... the RAM you choose will work. Here is another RAM with better timings... G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL7D-4GBPI - Retail It is DDR3 1333 verus DDR3 1600 you picked, but the decrease in timings will make up the difference between the two. Remember in memory, the lower the timings are... the faster the memory is...
  2. Alright thank you, I look over that same ram you recommended in my other post. Also, would you recommend switching to this board to take off a little more?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
    This board has the same combo with the GFX card (ASUS 4870 1gig).
  3. yea it is a very good board,i don't think you will need the extra things in the other mobo so yea go for it unless you intend to get more than 2 GPUs in the future it will be good for you
  4. Alright, thank you for the response. Assuming the combos stay and everything remains in stock I am ordering Monday morning. Thank everyone who helped me out.
Build RAM Systems Product
