Im upgrading my system to windows 7 64 bit and im running 32 bit vista so i needa back up my files. so my dad has a 1TB raid 1 server i believe and i hardwired it to my comp via ethernet cable. My mobo says its transfer speed is about 1gigabit/sec? which my dad says is bout 120 MB/sec so i should be transfering at that speed or like 100 but im transfering at like 8MB/sec... can someone please help me out i dont no why this is. Also when i open task manager and go to networking it says Adaptername: Local Area connection. Network utilization: ~7%. Link speed: 1 Gbps. State: Connected
DONT HAVE TO READ BELOW EXTRA QUESTION***
Also this is just another question i had i used the Windows 7 upgrade advisor and it says im compatible for 32 bit everything except my wireless netword card (its a 802.11g Wireless PCI card made by Texas Instruments, so its pretty old )and in 64 bit it just says compatibility unknown. do you guys think itll work...cause i really dont want to spend money on a new network card=\ Also im running a 2.6 GHz 9950 black edition AMD CPU incase you were wondering and 2gig of ram but plan on upgrading so figured id put 64 bit on now.
Thanks in advance,
John
Thanks in advance,
John
