My Computer specs.
Case: Antec Sonata 3
Power Supply: 500W Antec
Intel Core2 Quad 9550 2.83GHs LGA 775 95W
Gigabite EP45-UD3P Motherboard
G Skill 4GB (2X2 GB) 240 PIN DDR2 SDRAM 1066
WD 1TB HD
Zalman CNP 9500 Cooling Fan
GeForce GTX 260 Video Card (temp removed)
I have a problem. My computer did not boot up on its first boot. I have no power, no lights and no fans or anything.
I have the 24 pin power supply connected to the Mother Board. There is also another 8 pin connector power supply which is connected. I went over the connections to the front of the case and all looks OK + and - etc.
When I go to power-up and push the front switch, the led lights on the mobo flash on(the top 2 in red and the rest green. Then I have to reset the power for the lights to go on again.
I temp removed the video card
I would really appreciate any help!!!!!
WD 1TB HD
