Tom's Hardware > Forum > Homebuilt Systems > New System Build > Will this psu be a problem
Forum Homebuilt Systems : New System Build - Will this psu be a problem
This, CORSAIR CMPSU-850TX 850W is the psu i thought about getting for this build it is rated 12@70. I was wondering if this is overkill and if it will cause me problems? From what I know (which is not much) it shouldn't its just more than I really need. Thanks
http://www.newegg.com/Product/Prod [...] 6817139009
APPROXIMATE PURCHASE DATE: in about a week
BUDGET RANGE: 1000
SYSTEM
USAGE FROM MOST TO LEAST IMPORTANT: gaming, some graphic design, and some programming
PARTS NOT REQUIRED: CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, tigerdirect.com
PARTS PREFERENCES: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
ASUS Crosshair III Formula AM3 AMD 790FX ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Comb [...] mbo.211660
SAPPHIRE Vapor-X Radeon HD 4870 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102826
Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor 300 cd/m2 2500:1 - Retail
http://www.newegg.com/Product/Prod [...] 6824009145
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM x2
http://www.newegg.com/Product/Prod [...] 6822136319
OVERCLOCKING: CROSSFIRE: Maybe
MONITOR RESOLUTION: 1680x1050
OTHER THOUGHTS:
Sponsored Links
It's overkill for what you have now, but if you're planning to expand into crossfire at a later date with either the 4870s or 4890s or 5870s .....etc. it's a good move to cover your future options. You're spending an extra $20 over the Corsair 750w to give you a bit more headroom.
Reply to dirtmountain
The Corsair 850 is a great PSU and will work with your system. With what you have, I would recommend the Corsair 750w PSU.
Note on your GPU... Save some money & just get the 1GB 4870. It isn't worth the extra money.
You didn't list your case but if you live near a Microcenter, they have the CM HAF 932 for $120, which I would highly recommend or the Antec 1200
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Thanks for the feed. I think that I will stick with for the head room.
We don't have a Microcenter down here, would be nice though. Ended up getting the CM 690 mid for $80 but more room would have been good for the future and Tecmo is the second to suggest the 4870. I probably will go with that because I've really been stretching the budget on this one.
Reply to jsimeon
There are 1368 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
