Hello all, I recently bought one of these Fantom Drive G-Force 2TB external eSATA/USB HDD's. Not knowing that it has an idle timer builtin, compared to my older 1TB LaCie external I have which does not shut itself off, unless I specify it in windows 7.
I've been scouring the net and youtube to no avail. I cannot find any info on how to stop the Fantom drive from constantly powering down to a power saver/semi sleep state. It happens like every 5 minutes if idle.
I know Western digital Drives have a tool so you can change the drive firmwares idle timer setting, but so far; I have not found anything similar for this Fantom drive.
Does anyone know how to disable the timer, change it, or if there is an application out there that will ping/query the HDD drive periodically to keep it from suspending/sleeping?
Any help would be greatly appreciated. Thanks
- Chris
- Chris
