Hello!, I have taken a look at the specs of the dell dimension 8100, and I would like to know if your system look like this:
Proccessor: Pentium 4 1.5GhZ
RAM: 126mb
Hard Disk: 40GB
Video Card: ATI Radeon 9550 256mb
If you system looks like this I recommend upgrading you:
*RAM
*Hard Disk
*NOT REQUIRED BUT FOR BETTER PERFORANCE: At least a Pentium 4 with at least 2.5GhZ.
*The graphics Card looks ok.
As you can see unfortunately your PC cant run Medal of Honour Airborne, but if you want to try, you can download the DEMO at for example GAMESPOT. To see if it works. It probably wont if the specs that I posted are the same as yours. If you dont know what you system specs look like try this: http://www.systemrequirementslab.com/referrer/srtest this site will see if your computer can run the game. Just go to --select product--, and then selct Medal of Honour Airborene.
