Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Power led connector pin out
whats the pin out for the power led connector for the ga-6wmm7 rev 4.1 mainboard
Sponsored Links
its two little pins sticking up out of the mb , usually in the same block as all the other front panel switch and led pins .
It will be near the front of the case and at the bottom of the mb
Probably have LED or PWR LED written on the board in writing
If thats a bad answer , thats because it was a hard question to understand
Reply to Outlander_04
LED are polarity sensitive, plug it in one way, if it doesnt work flip it around the next time you open your case, it wont hurt anything the LED just wont work.
Reply to hunter315
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
