Hi
Most of you read the "The OCZ Vertex 2 Conspiracy: Lost Space, Lost Speed?" on Tom's > http://www.tomshardware.com/reviews/ocz-vertex-2-25nm-ssd,2867.html
An extract from the article below:
"...understood, OCZ can hunker down and address it. In desktop-class workloads, the 25 nm drives trade blows with the older drives. Really hammering the new SSDs with small 4 KB reads and writes is where they seem to choke up—and we think we know exactly why..."
Basically, apart from the "shorter" expected lifespan and slightly less (4GB or so) formatted available space of these 25nm "E" type Vertex 2 SSDs, it is said (as above extract) that the 4KB read/writes of these newer 25nm "E" drives "choke up" in comparisson to their former 34nm counterparts.
A lot of things were to be fixed (according to the article) in newer firmware updates - from 1.29 and up if I remember correct. Has some of these issues been addressed as I see the curent firmware version is 1.33 already?
I want to buy one of these drives and will most likely only be able to buy 25mn "E" variants as new only.
Please please please respond with some informative update/feedback
Much appreciated. Thanks
