Sign-in / Sign-up
Closed
Hello evry body i wanna the best way 2 overclocking my 2600k
  • Overclocking
  • RAM
  • VGA
September 17, 2011 9:19:39 PM
heello evry bod
my pc 2600k - p8z68 vpro - ram j skill 2 * 4 1600 cl8 - p.s coagar 700 watt - vga sapphir 5850 xtream 1g ddr5
please evry body i wanna to overclocking my sandy 2600k at p8z68 v pro with asafe way
and i wanna to to over clocking vga to the maximum mhz
waiting for urs opinion
theanks alot
More about : evry body wanna overclocking 2600k
a b K Overclocking
September 17, 2011 10:24:21 PM
Their is a "proper" way to O.C. but nothing about O.C.ing is safe.
Are you still using the stock Intel cooler?
What is your budget?
You should read the articles at the top of this section.It has all the info you need to know on how to O.C.
Score
September 17, 2011 10:33:26 PM
my friend i read the articles at top and i get an over clocking by auto way which at
asus AI SUITE
I GET 4.5 gh AT THE DEfULTE volt but i wanna increase to 5 gh or higher
my coller is C.M. V6GT
Score
a b K Overclocking
September 18, 2011 12:44:05 AM
Well you have the cooler all you gotta do is read how to O.C. and you can push it further.
Score
September 18, 2011 1:53:43 AM
ok iam trying but there is no stabiblity if i bush it further the maximum i arrived is 4.5 gh
not more with the auto overclocking
so i wanna to do it manually ok i hope to explain well for u my friend and i hope ur help
thanks alot for ur Patience
Score
September 18, 2011 2:26:32 PM
THANKS ALOT, GOING READ AND WILL SHOW THE RESULTS SOON
Score
a b K Overclocking
September 18, 2011 2:35:23 PM
Okay then.
Score
September 29, 2011 9:05:24 PM
hi .again
i iam trying to raise volte to 1.370 and multiplex to x50 but
i got none stable with intel burn for 15 min what can i do
Score
Best solution
a b K Overclocking
September 29, 2011 9:20:31 PM
Read the guide.I can't help to much because i'm not familair with Intel.I'm thinking you should top out between 4.5ghz and 5ghz.I haven't heard of many people going past 5ghz on air.
September 29, 2011 9:25:50 PM
OK WILL GET WATER COLLING AND TRY AGAIN THANKS ALOT MY FRIEND
Score
September 30, 2011 6:19:55 PM
Best answer selected by altowyran.
Score
a c 351 K Overclocking
September 30, 2011 7:04:58 PM
This topic has been closed by 4ryan6
Score
