When ever I play a game or do something graphic intensive, the program / game I'm using, crashes or sometimes the entire system crashes. I've had this problem since I built the PC.
I did some testing using a program called FurMark which logs GPU temperatures as well, whenever the temperature reached 72/73 Celcius, the program crashed. Is 72/73 Celcius GPU temperatur that high?
Thanks
those temps are rather cool for the 9800GT at load, the card will usually stay around the 80c mark when pushed (as mousemonkey stated)
check your CPU temps
------------------------------Recipient of multi-best answer awards and $3 power ball winner!!
Reply to ct1615
Have a look in BIOS and see whether it's set to auto or not and then use something like HWmonitor (
http://www.cpuid.com/hwmonitor.php ) to see what it sits at when in windoze.
Depending on the make of your modules the range can be between 1.78v (the lowest I can get mine to) and 2.20v (the highest I've gone) so check the manufactures website for specs. Some (not all, just some) SLi boards seem to like a bit more voltage to the RAM, especially if all the slots are populated.
Thanks I'll do that.
The crashes seem to random... I've tested the temps using FurMask and FanSpeed for half an hour the GPU temp went up to 88C and the CPU went up to 72C. There was no crash of program or system while testing. Really don't have a clue what's going on. I will do what mousemonkey suggested and report back.
I can't find what the voltage should be neither on their website or in the manual? Will it be writen on the board itself?
The JEDEC standard for DDR2 RAM is 1.8v which is what the motherboard should default to, some won't run properly at that especially when OC'ing is involved and/or more than two slots are populated. There might be a sticker on the RAM modules themselves giving type, latency, speed etc.
Don't you mean GPU and if so the thermal limit for a 9800GT is around 100c, I'm basing this on the threshold of my 8800GT's which are pretty much the same thing.
Message edited by mousemonkey on 08-25-2009 at 05:13:33 PM
Sorry mate, I thought you were referring to the OP, 100°C is the melting point for an E8400 as reported by Everest although Inhell reckon it's 72.4°C so it should have shut down or melted or the tj max is higher than Inhell states.
Message edited by mousemonkey on 08-25-2009 at 06:52:03 PM
I've checked the DRAM voltage in the BIOS and it's set to Auto. There are options ranging from 1.76V to over 2.0V, there is no 1.8V though. The closest one is 1.85V. What should I change it to?
