Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > I need a Rock-Solid i7 Audio Workstation
Forum Systems : New Build I need a Rock-Solid i7 Audio Workstation
I'll be ordering parts for my new Audio Workstation in a couple weeks. Click here for the current parts list.
Case & PSU: brand name is important here. Currently there are two cases in the list - I prefer the looks of the Thermaltake but I'm scared that it will perform poorly. Also in the list is a PSU that I'm unsure of because, all practicality aside, I'd like a black one.
GPU: I don't plan on getting a GPU until Starcraft 2 comes out (which may be awhile) unless it helps noticeably with my pro audio apps, which I doubt.
I have multiple monitors... but I guess I'm waiting until SC2 comes out to use more than one at a time.
RAM: I need at least 6GB RAM, but right now I have a 12GB pack because I hear there are disadvantages of getting a 6GB pack now and the same 6GB pack again later (once I upgrade from XP to 7) because they won't be "matched". Maybe you all can clear this up for me.
I have a personal vendetta against power outages, so the battery backup is important but I could be overdoing it with the wattage. Although for an extra $50 that's okay with me.
The ASRock mobo was a choice based on a sub-$200 i7 mobo shootout by Tom's Hardware.
I can't compromise on the HDD's because I need the storage (many audio-production apps are 20-40 GB+) and security.
I don't plan on OC'ing until I'm 100% confident I'm not going to mess up. But I've had non-OC'd computers randomly shutting down on me for awhile and I don't see myself OC'ing anything on this build.
Thanks in advance!!
Nathan
Message edited by ZildjianAVC on 08-03-2009 at 06:06:02 AM
Reply to ZildjianAVC
You need to make your wishlist public, oh and dont get the thermaltake PSU, get an antec, corsair, seasonic, PC power & cooling, or OCZ otherwise you are risking your system.
Reply to hunter315
How do I make my wishlist public? I set it to "shared" but apparently this isn't the same =)
You linked to your saved wishlist, go the the public wishlists tab and post that link.
Reply to hunter315
I don't know how to post the link in the public wishlists tab. lol
Message edited by ZildjianAVC on 08-03-2009 at 04:43:33 AM
This your wishlist?
http://secure.newegg.com/WishList/ [...] r=13676528
I just took the id number from the one you listed and put it into the public wishlist URL so im not sure if its still right
Message edited by hunter315 on 08-03-2009 at 04:51:40 AM
Reply to hunter315
yes! haha okay I fixed my original post. thanks.
Why isn't anyone responding? lol
Okay i had a chance to look over your wishlist, you need some sort of GPU as the x58 does not have onboard, get a 4670 or something. Also get an EA430 instead of the basiq, the basiqs arent very good but the earthwatts series is. Oh and you have 2 cases currently listed.
Reply to hunter315
Great, I switched out the Basiq for the earthwatts. I didn't realize that I'm missing an GPU, so I'll be doing some research on budget GPUs. Thanks for your input!
Message edited by ZildjianAVC on 08-04-2009 at 02:13:44 AM
You should look for a GPU that is fanless and low-power. GPU fans are annoying when loud, which is obviously bad for your ears while trying to listen.
Get matched RAM! This is extraordinarily important in audio editing PCs. Matched RAM allows you to have lower timings which correlates to lower latencies - critical for recordings and editing.
Edit: And consider replacing the stock i7 cooler, if you haven't already. That thing can get loud, too.
Message edited by frozenlead on 08-04-2009 at 03:07:34 AM
------------------------------ Desktop | i7 920 @ 3.8 | P6T | 24GB DDR3-1600 | 2x5870 CF | 3TB total | Corsair 850TX | HAF932 | XigDK | 2x24" 1920x1200 | Win 7 x64
Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17" | Win 7 x64
Reply to frozenlead
great stuff. any recommendations for CPU fans?
tomshardware rocks - I check this site several times a day, and have been for years. I also love newegg and buy almost everything from them, but had to snag an I7 from microcenter @$199. They have been promoting that for some time now in-store.
If you are at microcenter, might as well pick up EVGA's 141-BL-E757-TR which is $209 after $20 MIR, both at Newegg and microcenter.
If you are going to get an Antec PS, you might consider one of their cases that have them built-in, such as the Antec NSK6580 for $99 w/ the 430 PS. May be able to knock another $10 off with promo code ANTECAUG, limited offer.
Personally, I am a big fan of the modular CORSAIR CMPSU-620HX when discounted to $99.99 as it is now 139.99 w/ $40 MIR at newegg or the perfectly fine CORSAIR CMPSU-520HX when discounted $89.99 as it is now 109.99 w/ $20 MIR at newegg. If you don't need modular, you can save even more on these with the CORSAIR CMPSU-450VX at $49.99 after $20 MIR or CORSAIR CMPSU-550VX at $79.99 after $20 MIR or the CORSAIR CMPSU-650TX 650W at 79.99 after $20 MIR. johnnyguru has continually raved about corsair PS' forever.
Case and PS prices remain pretty stable so when on sale, snag them. Make sure after buying motherboard that you can install and test everything within a windo of returning - every mfr will have units that are DOA.
I'm pretty pleased with the NZXT Beta case I just got from newegg $39 after $10 MIR. It got a very good review on http://www.pureoverclock.com. However, it is being replaced by a revision that will be even better, but it is hard to argue with $39. I'm also a fan of the antec P183 and the nine hundred cases but again - for $39, this will suit me fine for this box.
Reply to Zombeezy
There are 2066 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Having Trouble Picking A Motherboard
By jsrudd, 30 minutes ago:
Here's a build that $976. CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($239.99...
Best offers
Top experts
