Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > 4850 x2 Display Problems
Forum Graphics & Displays : Graphics Cards 4850 x2 Display Problems
hi there,
ive just bought a new 4850x2 gfx card with 4 DVI heads on it and currently i have it plugged into 2x 22" LG monitors (1680x1050) and 1x Samsung 40" LCD (1920x1080)
Iuse my two LG monitors for gaming, web browsing and what not and use the Samsung for watching movies, blu rays and tv from the PC.
The problem i have is that even though ATI Catalyst Control & Vista say the Samsung is displaying at 1920x1080 its not, im losing about 3" from both sides and an inch from the top and the bottom of the screen, i cannot figure any reason why its doing this and wondered if anyone had an suggestions?
ive spent 350 quid just because i want 3 monitors and not two and now its doing this
Thanks
Reply to ollyrayns
You need to find a function in ati catalyst control which streches screen as you want. i guess nvidia drivers have it.
Reply to szymek
Had same problem with not being able to obtain better than 1440x900 resolution with Samsung T220. Downloaded latest NVIDIA update to version 1.2.0.82 then changed refresh rate to 60hZ.
At the lower refresh rate the full 1680x1050 resolution was available. Monitor works great now. Hope this helps.
------------------------------ I am learning here!
Reply to evongugg
I followed LuckyRazor's advised and flashed the EDID in my Samsung T220, and it did the trick
I copied the Raw data from his post into a file using HexEdit, and flashed the monitor using PowerStrip v. 3.83.
Or update edid via http://www.geocities.com/jgeneedid/EDID_Writer.zip
NOTICE: u should know that if u modify edid in your panel u lose warranty!
before u run command for rewriting edid go to service menu, it will disable write protection for while
how to enter service menu:
1. Set contrast and brightness to 0
2. Press the « Menu » button
3. Press the « Source » button for 5 seconds (the second one on the right)
for exit just switch panel off...
Reply to evongugg
There are 2077 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help appreciated
By 2fast4thetown_down, 2 hours ago:
If you have a 400 or more psu you should be fine it seems to be compatable just look at...
Best offers
Top experts
