I had that case and did not like it at all. Everyone was way too hot in the build. I switched a Antec 900 then Antec 1200 for a new build. I would go with an Anec 900:
Thanks for the comment. Besides that does the whole system look decent?
I am short on cash and already placed the order so that case will have to work untill I get more cash.
I was looking at the Antec Nine Hundred at first but it wasn't in my budget of $750.
Message edited by Dokioto on 08-04-2009 at 12:22:51 AM
You could have done better if you had gotten some stuff from newegg. I would have gone for the PII 940 and steered clear of that power supply. Physically everything should work but you could have done a bit better, hope you dont plan to game on the 790gx chipset.
Had it set-up at new egg.. Shipping was WAY to much then I wanted to pay. I do plan to game. What exactly is wrong with that chip set? I was told it was descent if your on a budget, hmm
it is, but you arent going to get playable frame rates at low detail out of it at anything higher 1280x1024, you really should get a discreet card if you want to game.
The motherboard you picked doesn't support SLI. You'd be much better off going with an ATI GPU with your setup if you're considering a multiple GPU setup. The 4870 1GB GPU's offer great bang for the buck. The only chipset that deals very well with SLI setups is the Intel X58.
right sli is nvidia technology and crossfire x is ati. Not compatible, only boards I know of that do both would be the i7 X58 motherboards.
You could do crossfire with the Biostar board with one caveat. I own the board and its a great little overclocker and has nice features BUT-the little heatsink sitting over the 790 chipset just below the ram slots is a super cheap thin metal, almost feels like tin. These boards are notorious for having high chipset temps.
My solution was to put an active cooler on the southbridge. However that blocked the second PCI EX slot. You could find a more robust passive heatsink for your chipset, but then if you put a second video card right over it you could still have heat issues.
Geo is right, you prolly should have asked for advice first. For now, I wouldn't recommend getting a second card for this setup. But an HD4870 should be able to play anything out right now, and they are easily found for under $150. Even an HD4850 is a great gaming card, and they can be found for under a hundred w/ a rebate.
I recommend finding room in your budget for a HD4850.
OK so I can have two ATI cards, got it.
I will pick up a HD4850 once I get the cash but from I have been reading it will work just fine until then. At the moment I have been playing Free games like Combat Arms and Operation 7 so it's not like I need a super system.
buzznut why would you not recommend getting a second card for this set-up? What's the problem.
What would be a better choice, a single GTX 260 or a HD4850?
Thanks for the help guys
Getting a crossfire capable board is a good idea, starting a build with crossfire isnt because there is usually a single card that can handle that resolution for about the same cost. Once you already have a card then crossfire is a cheap upgrade that allows you to improve your FPS.
