Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > WIfi 802.11b problem with Dell Latitde D505
Forum Laptops & Notebooks : General Laptops & Notebooks - WIfi 802.11b problem with Dell Latitde D505
Archived from groups: comp.sys.laptops (More info?)
I am having a problem getting my 802.11b network to transfer at full rate.
I have a home network with two PCs running XP and a Netgear 802.11b wireless
router. One PC is connected through the ethernet and the other through the
wifi.
I tried to do a file transfer from the wired PC to the Wifi PC that was very
long (>30 min). The icon on my system tray showed that the network set up
at 11M and stayed that way. But when I checked the utilization of the
wireless link in Task Manager, it showed a utilization of only 50% with
occasional short spurts of 100%.
DOes anyone know how I can figure out what the problem is? I want to get
the link up to full 11M.
Is there any issue of using WEP/128 bit encryption? Will that slow the
transfer down? Is there anything else that might slow the transfer down?
Thanks
Steve
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Sponsored Links
Conor wrote:
> In article <4097d68b$1_6@corp.newsgroups.com>,
> steven.gordon@mitretek.org says...
>>wifi.
> You won't, forget it. What you're getting sounds about right. At the
> frequencies of WLAN, things like Microwave cookers can interfere with
> it and it doesn't travel too well through objects.
Don't forget either that speed decreases rapidly with distance.
John Doue
Reply to Anonymous
There are 1098 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
