P palldat Distinguished May 16, 2011 1 0 18,510 May 16, 2011 #1 Hello, I was wondering how you determine how much power is needed to run a WD Passport SE 750GB hard drive. It gets power from the usb port
Hawkeye22 Glorious Feb 10, 2006 11,442 1 49,065 May 16, 2011 #2 USB 2.0 can only put out 5V at 500mA. Anything higher will require a power brick for the drive. Upvote 0 Downvote
A analytic Distinguished Dec 16, 2010 21 0 18,520 May 17, 2011 #3 Or a cable with 2 USB connectors (1Amp at 5V). Upvote 0 Downvote
ko888 Titan Feb 18, 2009 16,708 41 84,990 May 17, 2011 #4 palldat : Hello, I was wondering how you determine how much power is needed to run a WD Passport SE 750GB hard drive. It gets power from the usb port Since it uses a WD Scorpio Blue 750 GB Mobile Hard Drive: Electrical Specifications +5 VDC Current Requirements Read/Write : 500 mA (2.5 Watts) Idle : 400 mA (2.0 Watts) Standby : 50 mA (0.25 Watts) Sleep : 20 mA (0.1 Watts) Upvote 0 Downvote
