Solved
9800 GX2 power supply
My friend is giving me his 9800 GX2 :pt1cable: He hasn't been able to get it running on his computer
He said he might have fried it but i still want to try it out.
The only problem I am running in to is my power supply is lacking it wants a 550 W at minimum power supply and it is a 600W barley made it I still want a little higher wattage to be on the safe side. Also it doesn't have the 8 pin connector the card requires. Or a high enough amp rating. It think the Vid cards wants 40 Amps at 24 Volts. I read that some were but i am not sure if it is correct.
Since it may or may not work my I want a cheap power supply budget is around $50 maybe $100 if it a really good deal.
Do you guys have any suggestions for a power supply for me?
THANKS
7 answers Last reply Best Answer
More about 9800 power supply
  1. Go for these companies: Corsair, Thermaltake, Zalman, PCPower&Cooling, OCZ, Enermax
  2. Never skimp on a good PSU. Other ones to look for are BFG, OCZ, Silverstone/Seasonic, and Antec.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
    $80 OCZ 600W StealthXStream
  3. 9800GX2 is still a decent card (just at a really bad price point), just don't try 1920x1200 AND AA at the same time, and you'll be fine.
    Does it have a 8 pin connector? It said 1 x 6+2-Pin i am guessing that is a 6 pin with a little 2 pin connector that snaps together making it a 8 pin.
    This one only has an amp rating of 18A (same as the one if have now) Is that going to be a problem?
    Sorry it was 12V I am not sure where i got 24 from. So 12 V at 40 amps.
    Thanks
  5. Best answer
    That psu from newegg has 4 12v rails, it basically means that you have 18A x 4.
    And yes, the 6+2 connector is the same as an 8 pin.
  6. Ahh that is how it is how they do it i was getting confused because there weren't very many that when up to 40 amps.
    Thanks for all of you help!
  7. Best answer selected by catsrules.
Graphics Cards Power Supplies Computer Graphics Product
