Would you give me the maximum and minimum electric power required to make a cd/ dvd drive work?
G Guest Guest May 17, 2011 #1 Would you give me the maximum and minimum electric power required to make a cd/ dvd drive work?
Leaps-from-Shadows Splendid Jan 10, 2011 2,941 2 21,460 May 17, 2011 #2 That should be listed on the label of the drive itself.
4745454b Titan Moderator Apr 29, 2006 29,241 437 93,590 May 17, 2011 #3 Agreed, should be less then 5W.
ko888 Titan Feb 18, 2009 16,708 41 84,990 May 17, 2011 #4 Would you give me the maximum and minimum electric power required to make a cd/ dvd drive work? Click to expand... What is the make and model number of the CD/DVD drive? Is it a laptop or desktop drive?
