I will be purchasing my i7/285 build soon, but I'm having a hard time deciding on the peripherals. I can't decide on a keyboard/mouse combo or headphones. I'm looking for input.
I will be using the system for both web design and gaming.
This is what I was thinking of, but I'm concerned because it is not designed(or marketed at least) as a gaming set up. Would it work for gaming or am I better off with something else?
Logitech MX 5500 Revolution
Maybe this would be better?
Logitech G15
I would have to find a mouse to go with it though. Maybe this?
Logitech G9
And then we get to headphones.
Leaning towards these after the review that was on here a few days ago:
Logitech G35
A little concerned about usb headphones, but I was just going to use onboard sound anyways.
The other options are these:
RAZER Carcharias
These use a regular jack but are not surround.
Thanks for any input.
Logitech G15
Logitech G9
Logitech G35
RAZER Carcharias
