Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] What's the difference between 6-pin and 6+2-pin power connectors?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] What's the difference between 6-pin and 6+2-pin power connectors?
Best answer from hunter315.
http://www.newegg.ca/Product/Produ [...] 6817139005
It says it has "two 6+2-pin" power connectors. Is that the same as two 6-pin ones?
http://www.playtool.com/pages/psuconnectors/pcie6plus2.jpg
Thats a 6+2 pin connector, the extra two can be used so that it acts as an 8pin if the card needs it or they can be left unplugged and it is just a normal 6 pin.
Sponsored Links
Best answer
Reply to hunter315
There are 636 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
