Hello, I have a question regarding a 4U Norco server case that I have purchased for setting up a RAID.
Internally the case has 5 8087 connectors built into boards that interface with the drives. For more details on the case/interface look up the Norco rpc-4220 case.
I have a set of 5 SATA drives in the bays in the front of the case, but need a RAID controller card and cables to connect to the 8087 interface.
From what I can tell, most raid cards seem to have a 8484 interface, or something similar. Do cables exist to convert from 8484 to 8087? Do I need to buy a card that has 8087 connectors on it?
I'm trying to do a budget build on this machine, and most raid controller cards that have a single 8087 connector are already $500 and up.
I have found plenty of cards for under $200, but many do not list the connector style that they use, and I want to make sure I buy something that will work.
I've setup raid arrays in the distant past, but a lot has changed with sas/sata interfaces in the last 5-10 years, and it seems to me that every manufacturer has their own connector which just adds to the confusion.
Thanks for the help
RJ.
Thanks for the help
RJ.
