Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Monitor help
Forum Homebuilt Systems : New System Build - [Solved] Monitor help
Best answer from gkay09.
So I am just wondering what is a good monitor for gaming. Is 1920 x 1080 res good? or is it overkill? Would it be more economical to buy a cheaper one with less res. Will games use 1080 res? What GPU setup should i have to make use of the full capacity of 1920 x 1080?
lastly, what is the difference(other than size) in these two monitors, and are they good?
ASUS VH242H Black 23.6" 5ms HDMI Full 1080P Widescreen LCD Monitor 300 cd/m2 1000:1 (ASCR 20000:1) Built in Speakers
http://www.newegg.com/Product/Prod [...] 6824236052
and
ASUS VW246H Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 1000:1 (ASCR 20000:1) Built in Speakers
http://www.newegg.com/Product/Prod [...] 6824236049
Thanks for the help.
Both are good monitors, but hunter has pointed out the difference between those...
I would suggest you stick with the 1080p resolution and Yes games do look good @ that resolution...but to drive that many pixels, you need high powered graphics...
Cards like the HD 4890 or the GTX 275 are the best bet...
I would suggest you get a lower sized monitor (Not resolution) like this one...and spend $30 on the graphics side...
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen
http://www.newegg.com/Product/Prod [...] 6824236051
Sponsored Links
The 24" has a 2ms response time and has HDMI input.
Reply to hunter315
Best answer
Reply to gkay09
1920 x 1080 isn't overkill, it is called pleasure. :)
single 4890/gtx 275 will do the job for you. Don't settle for anything less.
Reply to masterjaw
There are 1051 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
