Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] UD3P/BIOS setting SpeedFan control of HSF Speed?
Forum CPU & Components : CPUs - [Solved] UD3P/BIOS setting SpeedFan control of HSF Speed?
Best answer from o1die.
UD3P/BIOS setting for SpeedFan control of RPM?
This is the Motherboard in my computer system.
GigaByte GA-EP45-UD3P (REV 1.0)
I'm using speedfan but I have no ability to move RPM's up or down.
I'm using a 4-PIN 'Arctic 7 Freezer Pro' is my HSF Fan/Heatsinc for cooling.
Since it's a 4-PIN Fan, whish settings should I choose to make the Fan Speed adjustable once I am booted inside Windows 7 and using SPEEDFAN?
What settings in the BIOS should I choose?
1. SmartFan Opions?
2. CPU Fan Mode?
I've already tried DISABLED and PWM mode and all it did was cause the Fan to spin way above it's max RPM and I couldn't lower the rpm/SPEED via SpeedFan
I hope REALLY HOPE someone can help me. I've been Googling myself to near death for months.
Try enabling smartfan and going into the options menu. I change the numbers to the lowest settings and the start up temp to about 40c. One fan was turning too slow, so it made a slight noise until I turned up the setting.
Sponsored Links
Best answer
Reply to o1die
Mine's up to 3150 RPM which is 750 above max RPM for this HSF Fan. Anyone care to comment on my IQ or writing style:gun: or help me figure out proper cpu cooling?
Why can't I get those 21-25C Idle temps? :gun: Mine **Never** is below 36C
:gun:
thanks all :pt1cable:
:gun:
celebration time, Cabrack Rol'Lama is President now..Whoo-hoo!
Message edited by weatherphobia on 11-09-2009 at 07:05:50 AM
------------------------------ Cabrack Rol'Lama is President now..Whoo-hoo
Reply to weatherphobia
There are 895 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
