Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > [Solved] Onboard Sound Vs. Card
Forum Motherboards & Memory : Motherboards [Solved] Onboard Sound Vs. Card
Best answer from SAAIELLO.
I have the EVGA E760 CLASSIFIED Motherboard.
The board has decent integrated audio.
Laying around, I have a spare Sound Blaster X-Fi XtremeGamer card
I wonder, is it worth using the SB card?
Reply to darkimage
Well, in most cases I would say not to go out and buy a card since onboard has improved so much. However, since you already have a (very nice) card laying around, why not? It can't hurt and should make your audio even better (although the improvement may be lost by the speakers).
------------------------------ 4 x AMD 6172 > Tyan S8812 > 32GB > X-1050 | i7 970 > P6X58D-E > 7970 3GB > 24GB | i7 3770k > P8Z77-V Pro > Classified 580 3GB > 16GB
http://piro.pirocast.net/badge/none/fah02/800/0/0/0/0/0/0/0/0/0/0/0/0/255/255/255/557101.png
Reply to EXT64
+1 use the card sound quality is no comparison between the onboard and an X-fi you would be crazy not to put that in. Dont forget to disable the onboard sound in bios before you install. ;)
Message edited by SAAIELLO on 01-29-2010 at 06:44:38 AM
Reply to SAAIELLO
Things is that's not a real x-fi card. Even the real x-fi don't sound that much better (I have one laying around). However you might have driver issues with creativelabs products.
Not only that but the card is PCI not PCI-E so you might get latency/clipping issues if you have a good video card.
I vote for the onboard.
------------------------------ 6510 8-bit CPU @ 1.023 MHz
64Kb RAM 20Kb ROM
VIC II
SID
Reply to MagicPants
Quote :
Curious about this bit as I have no idea how that would happen. I agree about the driver issues.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
Best answer
man i have an X FI PCI card and it sounds 10 times better then realtek and FYI creative fixed the windows 7 issue a cple months ago MagicPants has no clue what he is talking about if your worried about latancy issues there is a program that you can use to adjust that but i never experienced any problems. USE THAT X-FI MAN YOU will be much happier with sound quality versus that crappy onboard sound especially if its realtek or via crap, ADI is the only half decent onboard and even that cant compare to an X-FI
Reply to SAAIELLO
I doubt there is a program that will fix the "latency" issues that pants was talking about. I could see a program that will fix the problem you seem to be thinking of. I've heard of the issues that CL has had with vista, I'm assuming they exist with Win7. I haven't heard of it being properly fixed and welcome a link showing that they have been.
Always a DEMON!
Reply to 4745454b
Well I think I am experiencing that issue (stuttering) while playing COD MW2 on Win 7..don't know if it's the game or the card though (I also have an X-Fi Extreme Gamer)...haven't tried other games yet.
Message edited by dgre005 on 01-29-2010 at 03:01:43 PM
Reply to dgre005
Yes, yes it is :pfff:
The X-Fi Xtreme Audio is the rebagged Audigy SE/Live! 24
While I would never recommend anyone to purchase a new Creative product, you already have it and should use it.
It will defiantly give you better sound quality than any onboard CODEC.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
Most of you confirmed my thoughts that I should go ahead and use it. I am running 64bit Win7, and reportedly creative fixed the driver problems, so I will give it a shot.
Reply to darkimage
As a followup, I have installed the card and the difference in sound is off the charts! I originally purchased the card to go into my old P4 that had the RealTec on-board chip-set.
With this board having such a robust on-board audio setup, I had assumed that the gain would have been too little to bother. I was wrong!
Also, I had read quite a bit about problems existing with Creative Labs and Win 7 64 bit with regard to drivers, etc. They have an update on their site, and everything installed perfectly with no problems.
Thanks everyone!
Reply to darkimage
There are 2039 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Low profile ram for sabertooth 990fx?
By abekl, 2 hours ago:
Gskill and corsair ram are both very goos brands - on par with one another. I picked the...
Best offers
