Hey everyone, thanks for taking the time to read my posts
First off, here are my system specs:
Case: Coolermaster Centurion II (with a total of 5 120/140mm case fans)
M/b: Asus P7H55-M
RAM: A-RAM 4Gb (2x2Gb) DDR3@1300MHz
PSU: Gigabyte Odin 600W
CPU: Core i5 760@2.80GHz (currently running the stock cooler)
GPU: Gigabyte Nvidia GTX 560 Ti SuperOverclocked Edition
At the moment I'm looking at basically three main watercooling systems (self contained, factory sealed). These are:
CoolIT ECO A.L.C.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23_845&products_id=15098
Antec KUHLER H20 620
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_45&products_id=16986
Corsair Hydro Series H60
These are all around a similar price point (within $20) with the CoolIT being the cheapest and the H60 being the most expensive. For me, first and foremost would be quality - I don't want the slightest chance of a coolant leakage - with performance obciously important as well. I am planning on overclocking my i5 760 from 2.8GHz to as high as i can get it while remaing stable - most likely 3.5-4.0GHz.
Which is the best cooler fore me?
NOTE: I will probably replace the single stock fans with dual Coolermasters in a push-pull configuration, or something similar, so the fan quality isn't a big issue.
M/b: Asus P7H55-M
CoolIT ECO A.L.C.
