Well, here is my problem: I am getting severe crackling/popping which eventually leads to no sound at all (after 30-45 seconds of crackling). (The sound will come back if I exit out of the application, and sit at desktop for a few minutes) Now I know there is a known issue with X-FI sound cards and crackling, however I have owned this card for almost 3 years and have never run into any problems even remotely similar to this.
Also, after switching to onboard audio to test if my sound card was good or bad, I still got the popping and crackling although, not as much. So this tells me there is a larger underlying problem.
Now, I only get this issue when running certain games, such as Operatio Flashpoint 2, Risen, and a few other games. I do not get this issue when running less demanding apps, such as a media player or Zune software, also games like Counter Strike show no issues at all.
The problems started shortly after I installed my 2x ATI 5870's. Which led me to beleive that there was some kind of IRQ conflict between the vid cards and the sound cards. To test this I just did a fresh install of Windows 7 64 bit, however the problem came back just the same.
Here is where I think this problem may be CPU related: I reduced my corei7 to stock 2.66Ghz and so far (a few hours of testing) I have had no sound issues, then I bumped it up a bit to 3.33Ghz (still no sound issues as of yet)
If after a few days of gaming with no issues, can I safely say that my CPU overclock is somehow starving badwidth to the sound card in my PCI slot ? Is this even possible ?
Is it possible that my 2 5870's are stealing resources from my CPU, if so, why does slowing down my cpu SEEM to fix the problem ??
It seems like games that are more demanding on my system are more likely to make the sound issues appear, what does this mean ?
I am really at a loss right now, and I need some very professional input into this situation. Thank you for looking, please help me!!!
Message edited by annisman on 11-02-2009 at 05:38:24 PM
------------------------------Core i7 920 @ 4.0Ghz - Asus P6T - 12GB Corsair XMS 3 - 2X ATI 58701GB Crossfire- Zalman 850W - X-FI Fatality Gamer Pro - Xigmatek Thor's Hammer - Raptor X 150 - WD Black 1TB OCZ Vertex Turbo 120 GB SSD - Cosmos S Case w/side window + 8X 120mm fans
Try taking out the Xfi entirly during the test; simply being installed and running (even if not used) can effect the output. Could also be the result of the OC.
I have, I took it completely out, and even ran driver cleaner pro to remove any old creative drivers.
Still gave me crackling with onboard. Thank you for the post though, I really need all the suggestions I can get.
Reply to annisman
Really, if it happened when you installed the second 5870, the only thing you could try is to try with ONLY the newer of the two installed 5870, just to see if the GPU is somehow at fault.
Actually, I bought my two 5870's at the same time, so I never had just one installed, it might be a good idea to test them one at a time and see what happens.
Reply to annisman
