Cpu problem?
Forum Homebuilt Systems : General Homebuilt - Cpu problem?
I recently replaced my motherboard (identical replacement). At first it booted up perfectly. I rebooted a few times and then let it sit turned off overnight. The next day I did a couple more reboots, with no problem. I left it on and ran an errand, and when I returned there was nothing on my monitor. I turned it off and tried to reboot and got nothing but long beeps for the post and nothing else. All the fans are spinning, but nothing else is happening. Can you advise please?
Sponsored Links
Have you reset the CMOS?
If you don't know how, most motherboards have a reset button located near (usually) the CMOS battery. If there is no button, you can always unplug the computer from the wall, pop out the CMOS battery and let it sit for about 15 seconds.
Reply to aoster87
I would try to post with just one stick of RAM installed. If the system posts, manually set the RAM speed/timings/voltage to the manufacturers specs. You could then try to boot with both sticks of RAM installed.
Reply to shortstuff_mt
Thanks, I did this with no change. I appreciate your trying to help.
Reply to efray01
+1 to shortstuff
Try booting with only the HD, CPU, video card, and 1 stick of RAM. If it doesn't work, rotate each stick through each slot. Everything else can be unplugged.
Message quoted 1 times
Message edited by aford10 on 08-07-2009 at 11:21:48 PM
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Have you looked in the manual for your mobo and see what long beep codes represent (long continous beep usually means memory error. Steady long beeps may mean power supply. This differs with BIOs, however and they are not universal)?
Just saw Outlander's post. Use his link. +1
Message edited by rdawise on 08-08-2009 at 09:54:32 PM
Reply to rdawise
Thanks - no luck - I'm still searching around though.
Reply to efray01
No luck - thank you.
Reply to efray01
Thanks, but didn't work - still looking for solution.
aford10 wrote :
+1 to shortstuff
Reply to efray01
Did you ever check what that beep code means for your Motherboard?
Reply to rdawise
Yes, and I can't find the answer. I have Award Bios and either I'm not looking in the right place, or they simply aren't willing to share that information. The system is almost 8 years old, but still. If I had a POST
Reply to efray01
I'm sorry, I hit a wrong key and my reply was sent before I finished. I don't have a POST card so I can't determine what the problem is. The beeps are continuing long beeps that keep on until I turn the system off.
Reply to efray01
did you read the link I gave you which lists the beep codes for all the common BIOS?
Reply to Outlander_04
Yes, unfortunately, they are not very forthcoming about the Award Bios. I'm still searching. I've emailed the maker of the mobo as well.
Thanks.
Reply to efray01
Thanks.
its a memory error from your description
thats about as forthcoming as it needs to be
I would like to thank all of you for your suggestions. None of them worked, but just so you know, I switched out the mobo and put everything back on my old one and it seems to be working fine for now. The only thing I can come up with is that the "new" mobo was defective in some way.
I do appreciate all of your help.
Reply to efray01
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Cpu problem?
There are 820 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
