Tom's Hardware > Forum > Homebuilt Systems > New System Build > Cant Connect onboard Giga wired or wireless G Nic
Forum Homebuilt Systems : New System Build - Cant Connect onboard Giga wired or wireless G Nic
Motherboard: Biostar TA790GXB A2+
Memory: 2x 2GB Dual Crucial Ballistix 800MHz DDR2 4-4-4-12
Video: XFX nVidia GeForce 9400GT 550M 512MB DDR2
CPU: AMD Phenom II X2 550 3.1 GHz
PSU: Topower 650w
CPU Cooler: GeminII S
GigaN Router: D-Link DIR-655
Wireless PCI NIC: Linksys WMP54GS
WTF! I feel a sledge hammer comeing on!
Still Trying to get this rig working./week2 past 4 days on this alone.
Been trying to get a connection to internet. Been trying everything install, uninstall, upgrade, downgrade,start, restart, remove net security, switched NIC with known working one, you name it, nothing works either wired or wireless.
At best all I get is a message little or no connectivity, or no wireless networks detected. With old rig, same card and router could at least find the neighbors. Is there some setting in bios I dont know about.
Sponsored Links
Motherboard RMA time!
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
After a week of of frustration, turns out there was a setting or two in the router security was set way to high for it to see a new computer trying to connect. The most frustrateing part was I had 3 computers, 2 tivo's and a PS3 on a network that I couldnt fing through the new build. All working ant blazeing speeds. I would say thanks for the help but know one ever did. Prob solved.
Reply to hdshiftyman
For me, a week after my first install of Vista it stopped recognizing Optical Drives and Internet connections. You know what I did? Spent 2 weeks trying to fix it, even buying a new Card, then re-installing Vista, which fixed it! :na:
Reply to raybob95
There are 1252 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
