USB 3 vs 2 or eSATA Connection Issue
Last response: in Storage
I was asked to test hard drive speeds on our super computer
6 cores i7 970 extreme
12 GB Ram
windows 7 64bitpro
I ordered
Transend USB 3.0 PCI Express X1 Card
Nex Star Dual Bay Hard Drive Dock for USB 3.0
Hitachi 1 TB HDD
If I plug it into the usb 2.0 or eSATA slot it works seemlessly
If I plug it into the usb 3.0 slot it
I may not see a disk in disk management
If I do see a disk in disk management it will ask me to initialize it even though it is definitely already initialized
If I continue with the initialize MBR it will respond from Virtual Disk Manager"the system cannot find the file specified"
In the Disk Management graphical view it shows the disk as unknown
I may not see it in my computer
If I do see it in my computer I can enter it
If I try to create a folder or move anything into it it will respond "the system cannot find the file specified"
I'm tired, thank you for any help!
Since the vantec nex star dock seems to work fine connected to USB 2.0, it sounds like a host controller problem = replace your transend card. I would try the see if there are new drivers for it and/or try the docking station on another USB 3.0 system
Ask the community
